I am having several leaks from both engine and tranny ... 2 days ago I cleaned the area at the bottom from oil to isolate the source of the leak... and I realized the oil is leaking from the bottom where the shifter control cable goes inside the tranny and the area around is dry.
what seems to be the problem ?! .. should I open it up .. is there a seal inside ?! there are 2 or 3 bolts than can be loosened
