Hey guys,
I recently purchased a p12 ecu without doing my research and ended up buying a p12 ecu for and automatic. The issue with this is that upon warming up to normal operating temperature, the idle of the car tends to surge slightly. This can be rather annoying. Once the car is up to temp the problem goes away. So the only thing we are changing is preventing the surge that occurs on initial cold startup.
<<<<<DISCLAIMER>>>>>
THIS PROCEDURE REQUIRES A BASIC KNOWLEDGE OF SOLDERING ALONG WITH THE PROPER TOOLS. I SHALL NOT BE RESPONSIBLE FOR INPROPER USE OF THIS INFORMATION.
soldering is not too hard. youtube has many instructional videos of how to do so.
HERE IS A THREAD ON HONDA-TECH THAT IS SIMILAR TO WHAT YOU DO ASIDE FROM THE LOCATION OF THE RESISTORS BEING CHANGED. http://honda-tech.com/showthread.php?t=2969571
look through that thread and get the general idea of what to do then look at this picture
A jumper wire could be something like a paper clip bent in a U shape inserted through the holes and soldered in
This applies to all ECUs that share the same board (P11, P12, P13, P14 and P39)
this is my first real attempt at making a write up to help out. I havent found too many threads around concerning the p12 ECU. I just hope this helps.
cheers and good luck
-Sean
-Sean
