stalling at wot
    stalling at wot
    hello all...
    my 93 is stalling anywhere whenever i have to give it too much gas.. if i ease on the pedal slowly it will go fine, but anything over 2k rpm, in any gear, its stalling..
    car has 144k, 20k of which i have put on it in last year and a half
    dizzy replaced at 109k
    had a brand new honda distributor put on it in 07, and i just replaced the external coil with a brand new one thinking i had a failing coil. i did plugs when i bought it a year.5 ago. i have a brand new fuel filter ready to go, but im starting to think the fuel pump is failing. i can hear the pump turning on, and i have pressure and fuel coming out of the line.
    curious on some others thoughts on what to do next please
    thanks
    change the filter.. off the top of my head..maybe the FPR..or a vacuum leak to the FPR. check your plugs and plug wire connections too, air filter dirty? my crx did the same thing come to find out the cold air inlet i put on the bumper collected snow and the whole filter box had a chuck of ice in it with a little gap all around, so itd choke out if it wasnt being grannied (stupid ex gf)
      can anyone tell me where to connect this fuel pressure tester?? on my rail?
      and what is the fuel pressure supposed to be at idle and at wot or when giving gas?!?
