error code 41
    error code 41
    92cb7coupe here. Im pulling a error code 41, my water pump is leaking. I will do the timing belt and the pump like real soon. Is 41 code related to my water pump leaking?
    Thanks
    Anyone?
      1 O2A - Oxygen sensor #1
      2 O2B - Oxygen sensor #2
      3 MAP - manifold absolute pressure sensor
      4 CKP - crank position sensor
      5 MAP - manifold absolute pressure sensor
      6 ECT - water temperature sensor
      7 TPS - throttle position sensor
      8 TDC - top dead centre sensor
      9 CYP - cylinder sensor
      10 IAT - intake air temperature sensor
      12 EGR - exhaust gas recirculation lift valve
      13 BARO - atmospheric pressure sensor
      14 IAC (EACV) - idle air control valve
      15 Ignition output signal
      16 Fuel injectors
      17 VSS - speed sensor
      19 Automatic transmission lockup control valve
      20 Electrical load detector
      21 VTEC spool solenoid valve
      22 VTEC pressure valve
      23 Knock sensor
      30 Automatic transmission A signal
      31 Automatic transmission B signal
      36 traction control found on JDM ecu's
      41 Primary oxygen sensor heater
      43 Fuel supply system
      45 Fuel system too rich or lean
      48 LAF - lean air fuel sensor
      54 CKF - crank fluctuation sensor
      58 TDC sensor #2
      61 Primary oxygen sensor
      63 Secondary oxygen sensor
      65 Secondary oxygen sensor heater
      71 random misfire cylinder 1
      72 random misfire cylinder 2
      73 random misfire cylinder 3
      74 random misfire cylinder 4
      80 Exhaust Gas Recirculation insufficient flow detected
      86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
      90 Evaporative Emission Control System leak detected in the fuel tank area
      91 Fuel Tank Pressure Sensor low input
      92 Evaporative Emission Control System insufficient purge flow
      TCU Codes:
      CODE LIST:
      1-Lock-up solenoid 'A' circuit open or shorted.
      2-Lock-up solenoid 'B' circuit open or shorted.
      3-Throttle Position Sensor circuit open or shorted.
      4-Vehicle Speed Sensor open or shorted - No signal from speedometer.
      5-Shift Lever Position Switch circuit shorted.
      6-Shift Lever Position Switch circuit open.
      7-Shift Solenoid 'A' circuit open or shorted.
      8-Shift Solenoid 'B' circuit open or shorted.
      9-Counter shaft or transmission speed pulse generator open or shorted.
      10-Coolant Temperature Sensor open or shorted.
      11-Engine RPM (Ignition coil signal) open or shorted.
      12-(No code 12 used)
      13-Main shaft speed pulse generator open or shorted.
      14-Linear (line pressure control) solenoid open or shorted.
      15-Kick down switch circuit shorted.
        disconnect and remove your oxygen sensor, check the wires if they are in good condition, else, clean your O2 sensor and re-install it, remove the fuse to reset the ECU and check again.
        if the problem persists then you have a bad O2 sensor.
