t2t4 transmission issues
    Ok so I have the LSD t2t4 on my h22. It shifts like butter in every gear. But when you put your shifter in neutral and pull all the way to the left it pops back to the middle. And when you pull right it's suppose to do the same thing. But mine gets stuck all the way to the right like in between 5th and reverse and doesn't pull itself back. And just feels a little gushy like i'm pushing againt rubber around the 5th and reverse area. Also I can't go from 5th to 3rd could this be a lock out cause the tranny is so high geared. And could bad shifter cables be why it's not going back over to the middle?
    Clean and lube your shifter and make sure your cables aren't binding. Check your shifter cable bushings as well. That's all I can think of right now.
    YouTube Clicky!!
      k thinks will do.
