Bad main relay problems?
    I got my h22 swap running right and everything was great until I took it to my girls and stayed the night. I went to start it and it turned over and would catch but die right away. Then when I got it turn turn over and stay running when I gave it gas the rpms would drop and choke down. I heard two clicks for the main relay but the cel stayed on which is for the vtec op. sometimes it'll try to run. Any ideas? New battery, alternator, starter, battery harness, averaging 150-155 psi in all cylinders, getting spark and fuel but I haven't checked if the injectors are spraying. When I took the fuel line off of the fuel rail there was a lot and i mean A LOT of pressure. Gas went every where. Test light to check spark. and timing is dead on.
    JDM powered CB7
    I just thought of something.. I'm reusing my egr valve from the f22 and the f22 had the same problem. That'll be something to check tomorrow..
    JDM powered CB7
