I GOT A FREE CB7! Aside from the towing expenses.. But I went and got it from this guy and he said the transmission acted like it was in neutral after he shifted into 5th. I can shift it through 1st-5th and reverse no problem but it doesn't move in any gear. It's not too big of an issue since I have a trans ready to drop in, I'm just wanting to know what could be wrong with this one. Thanks.
5 Speed trans acts like its in neutral...
We jacked the front up, rotated the wheels forward until they were spinning a good bit and threw it in reverse and it grinded and the wheels stopped so I guess that's all good? I saw on youtube where ericthecarguy diagnosed a blown clutch and that's exactly what this car does except it doesn't choke down.
JDM powered CB7
could very well be then, umm maybe try rolling it and pop the clutch and see if it starts..that exhausts my manual knowledge since i run a slushbox..sorry man but sounds like youre on the right track anyway..only other bet is when you pull the trans and can take a look. dude probably had a worn clutch and burned it out. Give it a day im sure some other people will chime in. good luck.
Okay good, and I don't see any oil leaks, only leak is on the timing side, which will be fixed when the timing kit comes in. I'm still waiting to take the transmission off so I'll be able to see if it's the flywheel, clutch, fork, pressure plate, or anything to do with engaging the clutch.
JDM powered CB7
I had this happen to me in a civic 5 speed. It was stuck in fifth all the way home from work and when I got home I managed to get it out of fifth. It stayed in neutral no matter which gear I tried to put it in. I don't know exactly what broke but I had to put a new transmission in. I feel like if it where your clutch the wheels would move a little bit.......father in law has it back again. Time to shine
