i heard that honda valves tick a little loud is this ok,its not killer loud but its noticable??
ticking valves
i think its more of clicking increasing wiht rpms...
i have this...dont have the time and patience to adjust my valvesWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
my valves, or something under the valve cover is starting to get a lil loud, i opened up my oil cap and looked inside with a flashlight, one of the screws, closest to the cap was dented on top closer to the front bumper, like its been banging against the valve cover.... maybe i should start getting some info on this so i can have something to do over the weekend cuz its starting to get me worried, thanks guys....
If you're going to adjust them yourself, it's not that hard, just keep a manual on hand. I'd recommend using the Honda valve adjustment tool, otherwise you'll be fiddling with it forever to get it right. If the noise is increasing pretty quickly over time, might be that the cam is wearing out, which increases the valve clearance. Take a look at it when you take the valve cover off. You can sometimes re-use the gasket, but I would suggest replacing it... It's not all that expensive, and it'll make sure you don't have oil running all over your exhaust manifold or intake manifold like I did...
-Ryan-
My life is rated R.
