In the winter, long before I did my manual transmission swap, I replaced the distributor seal. Upon initial start up after reassembly it had a really bad miss and it would stumble fairly hard up until about 2000 RPM's. It would worsen as the accelerator was pressed and would lessen as the accelerator was released. I figured it was due to the ignition timing being off.
Yesterday I did the following:
-Replaced the TPS. Set the TPS at exactly .45 volts closed. Reset the ECU.
-Cleaned, tested and re-installed IACV.
-Bleed the coolant system.
-Replaced the spark plug wires with NGK wires.
-Set the base idle properly at 700-800 RPM's.
-Put the ECU into base ignition timing mode then set the base ignition timing at what I believe to be perfect or near perfect (15* mark).
-Reset the ECU.
The condition has improved as it now takes more accelerator pressure at a lower RPM to make it miss. But the miss is still just as bad when it does it.
After preforming the manual transmission swap I had three CEL's on initial start up. 12, 14, 41.
12 was due to the vacuum line on the EGR valve being cracked. This was fixed immediately.
14 was due to the IACV being unplugged. I did this and I forget why now.
41 was due to being ran briefly with no downpipe after the manual transmission conversion to ensure the procedure was preformed correctly. On my F22A4 the oxygen sensor is in the downpipe so there was no oxygen sensor at that time.
There are no CEL's currently and I have put 100 miles on the car since resetting the ECU for the final time yesterday.
I know the fuel filter is due to be changed as well as the spark plugs. However I don't think this is the issue.
I'm thinking it may be a weak coil or possibly something incorrect in the distributor although I'm fairly certain I did in fact do it correctly.
I was wondering if anyone had any idea as to what this may be. I apologize if this is to much information, I tend to do that.
-Reset the ECU.
