Title says it. Some how, some where there is water leaking into my car. It's not rain, we've had a dry week. It was dry, then when I start the car and turn it off water pours into the passenger side. There's more water in the back than the front. The AC was taken out but all that was removed was the compressor and hard lines in the engine bay. Nothing was plugged. Help please ?
Water leaking into cabin...
Check the heater core hoses going into the firewall. One has a valve on it. If the heater core is deleted the hoses need to be removed and the water necks caped off. If that's been done.Last edited by H311RA151N; 08-15-2014, 03:36 PM.
That sounds like the culprit, I'd suggest to keep the car parked until you can fix it. Who pulled out the A/C? I believe there's a little more to removing it properly, I did a quick search on the forum and found some answers, however my iPad refreshes each page when I visit them so I can't post any links. Just search AC delete or AC Remove.
Both hoses are fine, the valve moves when I turn the temp knob from cold to warm, and it was on cold the whole time. It's on hot now and there isn't any water leaking from it, at least from what I can tell. I pulled the carpet up and checked to see where the water is coming from but couldn't tell./:
JDM powered CB7
