Hello I just wanted to know I it safe to adjust distributor with the car off then reset the ECU? Will it still make the adjustments with the car off or could it just mess things up?
Adjusting Distributor With Car Off
It's good enough to allow the engine to be safely started, but won't guarantee correct ignition timing. Next step should be to 'hot-wire' the diagnostic port (blue plastic electrical connector under the dash) with a piece of wire and set the base timing with a timing light.Originally posted by Kev1990 View PostHello I just wanted to know I it safe to adjust distributor with the car off then reset the ECU? Will it still make the adjustments with the car off or could it just mess things up?Regards from Oz,
John.
