On my transmission I have broke a tooth off of the cable mount thingy where the cable lines are held into place. I don't know what it's called and I was wondering if there is a part number for this?
5 Speed Trans Cable Mount Bracket
Not sure what part you're referring to. But see below
http://www.hondapartsunlimited.com/a...ift-lever-scat
http://www.hondapartsunlimited.com/a...h-housing-scat
My guess would be the bracket directly to the left of 19. I made mention of it in my 5 speed conversion DIY (as it's part of the conversion). It bolts to the bottom of the subframe via two 10mm bolts.
It appears to be a part of the cables as it's not listed. It may be listed under another system but I don't care to take the time to check and I don't think it is. I just don't know what part of the bracket one would refer to as a "tooth".
he's talking about the Cable Stay Bracket, #10 in this picture:
I'm pretty sure I have a couple of those sitting in a box downstairs.
Yes, that's it. I don't know how I've broken these, but the clip doesn't hold in very well and I'm afraid it's going to come loose. With the new H22 I bought I did the same thing while trying to get the clips off. I don't know if it's because they are old and brittle or if I'm being too rough.Originally posted by cp[mike] View Posthe's talking about the Cable Stay Bracket, #10 in this picture:
