So my car is an auto and when i come to a stop and start going again, the motor just revs like its in neutral. Only thing that fixes it is if i turn the car off then back on again. Ive teied a different tcu but the one i got wouldnt go into drive at all. Whats happening? Fluid is good not burnt and full. Im out of ideas
automatic transmission help
Exactly.Originally posted by s2cmpugh View PostIf your experiencing slipping between gears or while engaged in a gear, then there's a good chance the transmission is toasted. Check the fluid level and condition to see how that looks.
If there's no error code, there was never any need to replace the TCU or mess with the shift solenoid. Can't hurt, but it's just wasted money if you paid for that stuff.
The last thing you could try is changing the transmission fluid (when is the last time you did that?) If you really want to do it right, drain/fill/drive/repeat 3 times. It's expensive, and a waste of fresh fluid, but it will ensure you get all of the old fluid out of there. If you don't want to bother, then a simple drain and fill will suffice. Be sure to use Honda ATF. Nothing else. No additives, no fancy aftermarket junk. Honda fluid. Plain and simple.
