Can anyone tell me what tb's are compatible with a F22b DOHC OBD2?
Throttle Body for F22b DOHC
Any F/H-series throttle body with the exception of any of the F20A/F22A units. Also most B/D-series throttle bodies will work, but some may not be large enough in diameter. Basically this answer applies to aftermarket and OEM, but not all will have the FITV on the bottom of the throttle body like your current one does.
I must ask, though, why do you need one? Given the content of your other post it's hard to imagine anything being wrong with your current one. It sounds like you're not listening to the answers that were given and you're trying to throw money at a problem.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Thank for the reply!Originally posted by Jarrett View PostAny F/H-series throttle body with the exception of any of the F20A/F22A units. Also most B/D-series throttle bodies will work, but some may not be large enough in diameter. Basically this answer applies to aftermarket and OEM, but not all will have the FITV on the bottom of the throttle body like your current one does.
The swap for my engine happened back in October and my mechanic said that he did not hook something up correctly. This has been the first time I have had time to work on the car; however, I did not remember what he told me was disconnected.
I should have called him first but I went investigating on my own and that did not work out well, as you have seen. But I called him and he said that I needed a new TB because the TB is manual and the car is auto.
Go back to your original post and post up all of the information you have on your swap and the current t symptoms. Any pictures you could post would be helpful. Did you source your own parts or did he?
From this point forward, cease calling this guy for advice. He doesn't know what he's talking about. He can't transfer a kick-down cable bracket over?My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
