I am getting a code 9 for the CYP sensor and I can't get it to go away. I am hoping the experts here can offer me some advice.
The original problem was that the CYP sensor in my 1997 F22B1 Accord distributor is incompatible with OBD1 ECUs. Thus, my OBD1 P72 ECU threw a code 9 with my 1997 F22B1 distributor, even though there were no codes with the 1997 ECU.
To fix this, I installed a 1991 Accord distributor (1990-1 distributors had an internal coil, as did my F22B1 distributor, but 1992-3 and F22B2 distributors used an external coil). I created a custom wire harness from the 1991 distributor to the 5-pin distributor connector on the 1997 Accord wiring harness for the F22B1.
I only rewired the 5 pins from the 1991 distributor: CYP +/-, ECU signal, power, and tach output. The OBD1 ECU seemed happy with the CKP/TDC signals from my crankshaft position sensor and did not throw any codes, so I did not wire up the CKP/TDC signals from the 1991 distributor.
I installed the 1991 distributor and the MIL turned off - for a couple minutes. Then the code 9 came back. It now comes back almost immediately after I clear it. The engine runs exactly the same way as it did with the 1997 distributor (some minor stumbles during warmup around 2000 rpm, otherwise runs fine).
So, I got out the manual and did the diagnostic checks. Over the last 2 days I checked the resistance across the CYP sensor three times - at the ECU pins - and it read between 375 and 450 ohms each time. Spec is 350 to 700 ohms, so this should be fine (my F22B1 distributor had resistance of 787 ohms across the CYP sensor). I also checked continuity between the CYP pins at the ECU and ground and this was fine as well.
So, I'm stumped. Is is possible that the distributor could pass the diagnostic checks and still be bad? Should I try a third distributor?
Or, how likely is it that the ECU could be defective? Outside of this, the ECU seems to be working fine. Also, PureTuning in Toledo chipped my ECU and installed a Hondata S300 and he was pretty picky - he rejected the first ECU I bought because he didn't like the soldering on a few pins and made me buy another one.
