Cold long cranking with check engine light.
    I have been real busy so I haven't had time to really get into it. This problem started about a week ago. Like said, it cranks a lot before it starts when cold and check engine light comes on. I can let it run for a minute or two then restart it fast with no check engine light. If I don't restart to get the Che k engine light off, it sounds like I'm hitting a Rev limiter at 4K. I also have a problem with no speedo and flashing S light for the first 5 minutes when cold. It only does that sometimes but the long start and check engine light happens every time. I'm not looking for how to fix it. Just looking for some input on where I should start checking to help same some time. The car has new plugs and fresh oil.
    1991 Accord LX .
