I noticed that my radiator fan does not cycle after turning my car off to cool it down. The fan will turn on if I have the key in the ON position and will turn off when the motor gets around 190*. Went to the junkyard today to get a fan timer unit and tried it out but still no fan cycle after the engine was warmed up then turned off. Unless the timer unit I got today is faulty, anyone have any idea what might be the problem? Thanks
Troubleshooting coolant fan
Would the sensor see the change in temperature after the car is turned off, to then trigger the fans? My external temperature gauge shows that coolant temperatures go up to 215* while my cluster temp gauge reads right below that halfway mark after driving the car. Mind you this is a boosted motor with an aftermarket ecu, not sure if that would affect anything. Thanks for your response.Originally posted by QuashishHoly crap thats a clean F series. jellish mang.
Quashish dictionary
Jellish: (adjective) Jel-%i'sh+#
To envy something to point of almost blowing a load involuntarily.
