Ok so before anyone decides to rip into me:
- I searched the forum and found a similiar isssue :
Coppertone March 2011
Unfortunately nothing was ever solved in that thread. So here's my issue:
Outline:
I recently swapped an h22a into my 92 Accord, used my ry-wire subharness and wired everything up like I've done so many times before (3rd swap).
When I purchased the motor I was given an OBD2 distributor for this motor when I purchased it so I converted it from an OBD2 internal unit to an external OBD1 unit for the car, pretty simple and straight forward.
I went to a local tuner shop and he gave me a set of OBD2 H22a injectors in which I found I had to by pass the resistor box :
h22 OBD2 injectors
So after that mod, I tried to start it and it was getting a very strong spark but would not fire up, so my friend showed up and it turns out the firing order was wrong, so we switched the wires and voila it fired up and ran..for about a minute and then shut off.
Discovered that on top of the H22 TB there's a 90 nipple that if PLUGGED off would keep the car running, BUT if you gave it gas it would die out.
I understand that nipple is for the Charcoal canister but the red hose won't fit over it. So I tired to by pass it by blocking it off.
On Saturday morning before work I tried to fire it up, it does get spark, fuel , combustion and compression so I know it works, bad idea on my part is that I tried to use brake clean as an alternate source (which worked) but I completely forgot that the injectors (f22a1s) weren't sealed tightly..thus it started a fire.
Luckily no damage was done as I quickly extinguished it.
Cleaned it up, took out the f22ax injectors and put h23 ones in their place but now here's this NEXT kicker:
It will run on ether for a few seconds and then just die. I'm assuming until the ether itself burns out..
HAS anyone on here ever experienced a similar situation?
I've googled and it's taken me to SuperHonda , Preludepower , here (respectively) and even Honda-Tech with no known fixes.
Cliffs:
- Swapped in an H22a
- Changed injectors to OBD2 H22s and by passed the resistor box.
- Switched back to the single cam f22ax injectors and on attempt to start it backfired thru the intake manifold and caught the gasoline spray on fire
- Switched back to OBD1 h23 injectors
- Has spark, compression and combustion
- Used ether to start it and it WILL run but not for long (about a minute)
Can anyone
Outline:
h22 OBD2 injectors
Cliffs:
Can anyone
(Love the Frankenstein look!)
out with the old and in with the new
