Ok... here's the deal. I was driving down the road and the car just died, I was going down a hill so the engine was turning with out actually being on. Thought it could have been the ignition coil but it isn't. I am getting no spark before and after I swapped the coil... I am stumped, it cranks, the timing belt is not broken and there is no physically apparent damage to anything around the ignition system. Has anyone encountered this problem in the past? If so, did you find the solution? Thank you in advance and have a great day.
No spark, no start... help!
I've got a fuel supply system and vehicle speed sensor codes... my speedometer does goes in and out. Let me look into the fuel system and then re-post.
Codes 17, 41 and 43.Last edited by Apexbender; 08-29-2015, 05:41 PM.
Checked the wiring and it works with an external ignition coil so the igniter is not like in the video above but the wires are alike so I checked and got no signal so I swapped the distributor and it is running like a champ! I will figure out if I can fix the old one with a new igniter so I can sell it forwards. Thank you again and have a great day!
