injector testing voltage.
    Whats the correct voltage for the injectors , I was just using a single c 1.5v which does make them click and open , but wondering if it's suppose to be higher.
    Just don't want to break them pumping in too much voltage. I'm just doing the basic self cleaning procedure with the can and a little home made fitting to attach them to the can.
    I'm guessing they might not be opening all the way with a single 1.5v battery
    12v, with a resistor to limit the current (i.e. the resistor box)
    You should use a 9v battery. It can supply enough current to open them without frying them.
    YouTube Clicky!!
