I installed a new head gasket in a 1990 CB7 F22a1, and it's leaking oil into the coolant. I'm not sure what I did wrong, I followed a diy tutorial explaining on the procedures that needed to be done. I exchanged the head for a re-man off ebay, cleaned the block up with a razor and torqued the head to spec and timed everything correctly. Any suggestions on what I need to do to fix this problem, and my biggest question is can I re-use the new head gasket and head bolts I don't want to have to re-buy those things.
Thank you for the help!
I'm glad it was that simple.
