Im having a starter issue. The starter is new, the signal wire attached to it is not getting 12v. I could jump the starter with key in on position, and the car starts up fine. So I'm not sure what it could be.
Starter issue
You answered your own question! You have an open circuit in that wire that doesn't have power.
Start by checking for power from ignition switch, and checking the solders on your main relay.
Is it a manual transmission? Check to see if you have both clutch pedal bushings, if so, jump the safety switch and see if it works.
This, he is talking about the switch on the clutch pedal in the car.Originally posted by F22Chris View PostYou answered your own question! You have an open circuit in that wire that doesn't have power.
Is it a manual transmission? Check to see if you have both clutch pedal bushings, if so, jump the safety switch and see if it works.......father in law has it back again. Time to shine
