My rear defroster, among other things(which I'll get to later)has not worked for the better part of 2 years. After doing some reading, outside of fuses which I have checked, both in car and under dash, the integrated control unit is the issue. I came to this conclusion as my dome light does not work, no chime when key is left in ignition, no intermittent setting on wipers.
My question is, is the best way to resolve these problems to replace the whole unit, or can it be repaired in anyway? I did quite a bit of searching, both on here and Google and didn't turn up much on how to actually replace the unit.
Any information on this job would be much appreciated. Also, is an integrated control unit from any 90-93 Accord okay? Or does it need to be specific to your year/model? I have a 1990 LX 4 door.
Thanks,
Thanks,
