Vibration noise
    Vibration noise
    So after chasing this noise for a couple of days turns out my power steering belt is rubbing on the inner crank pulley. I was wondering if anyone has had this issue. Nothing has been altered I did replace the alternator a month or so ago. everything was perfect then it just started making a noise the other day and now this. 91 cb7 a4 motor. thanks for any input sorry if I left anything out If more info is needed just ask and I'll let you know.
    1990 CB7 *RIP*
    Current-91 EX and 92 EX
    I've had a few (2) crank pulleys come apart completely on me before. Granted I'm H22, they still shouldn't have failed the way they did. The entire outer ring separated from the inner ring.
      Damn. I had searched the forum and I had seen post about the crank pulley so I checked it out. No wobble no cracks no noise when I pulled the power steering belt off and ran the car I'm fairly certain the belt is bad and stretched from pulling it off so many times that it's causing my issue
      1990 CB7 *RIP*
        Yeah those crank pulleys suck. i snapped one From force trying to remove the crank shaft bolt .
        I think those aftermarket lightweight ones are supposed to be okay.
        sold! But here's my build thread for those interested.
        http://www.cb7tuner.com/vbb/showthread.php?t=206864
