Automatic throttle body on car with manual transmission
    Working on a H23 plenum swap. The throttle body came from an automatic transmission prelude. Getting a surging idle.
    I'm guessing my FITV is either bad or needs adjustment but I noticed there are different part numbers for FITVs for automatic equipped and standard equipped cars. Is there a difference? Should I care?
    92 Accord EX. Thanks all...trying to get her ready for a HDPE track weekend this weekend.
    1992 EX, 306,000 miles - Track toy - M2S4, H23A1, ST rear swaybar, Wagon brakes, GC coil sleeves, KYB AGX dampers, Stoptech pads, Toyo Proxes R1R, 2.25" exhaust
    Stock F22A6
    VIR, 5/22/2016: https://youtu.be/eR5-ylSPsxk
    H23A1 powered
    NCCAR, 9/4/2016: https://www.youtube.com/watch?v=TI5WpxGrEpE
    CMP, 10/16/2016: https://youtu.be/DOqoe5f-GLY
    After a FITV rebuild the throttle body is working fine. The o-rings were all dried out and probably leaking a lot of air.
    Stock F22A6
    H23A1 powered
      Good work on finding the problem and correcting the issue.
      CB7TUNER.com
      Educating each other one car at a time.
        Thanks for everyone's help on this car, I just finished a successful track weekend at Carolina Motorsports Park, 2.5 hours of track time, no mechanical issues at all. Car did great.
        If anyone is curious here it is chasing a couple BMWs: https://youtu.be/q6N741iJRZk
        https://youtu.be/cl7_RYhLVpw
        Stock F22A6
        H23A1 powered
          Awesome man that looks like a ton a fun!!!
            Just wanted to add - R134a refrigeration o-rings (the green ones) are excellent sizes for rebuilding the FITV. I bought this kit and it had all but one that I needed.
            Stock F22A6
            H23A1 powered
              Thanks, it was! would highly recommend it!
              Stock F22A6
              H23A1 powered
