I have a little coolant leak at the neck and when it pressurized, it leaks out like in the photo below. I am looking at it closely and it seems to be coming out of the lower neck of the radiator. I wiped it clean to see where's coming from but cannot pin point it. Could the neck has a slight crack?
I cannot see anything leaking from the cap and the cap is relatively new about 2 years old. The reserve reservoir hose seems intact with no leak visible from it. What could it be? If at the neck, is there a way to repair as I don't have the cash to replace the radiator. The radiator I know from the maintenance record of the previous owner, was replaced once.
Thanks.
Thanks.
