so im in the process of wiring in my map sensor on the TB and eliminating the black box and im wondering what wire goes to what spot on the map sensor.
I had an extra harness laying around so i just cut the TPS plug off since its the same and i got the MAP sensor plug off the black box and cut that plug off als.
wondering if its just match the "alike" colors or if it is different.
also wondering about the EGR portion of it, as i wont be running EGR it shouldnt need to be plugged in right? i will have a hondata s300 so im pretty sure i can disable it on there.
also the plug that will plug into the MAP is top view so the green/blue will go towards the firewall
and a link to my build if anyone is interested
http://cb7tuner.com/vbb/showthread.php?t=204851
