Ball and socket ("zero lash") style end links
    Are these available for CB7's?
    This is the style I'm talking about:
    Would be an easy way to increase roll stiffness without replacing the bar.
    1992 EX, 306,000 miles - Track toy - M2S4, H23A1, ST rear swaybar, Wagon brakes, GC coil sleeves, KYB AGX dampers, Stoptech pads, Toyo Proxes R1R, 2.25" exhaust
    Stock F22A6
    VIR, 5/22/2016: https://youtu.be/eR5-ylSPsxk
    H23A1 powered
    NCCAR, 9/4/2016: https://www.youtube.com/watch?v=TI5WpxGrEpE
    CMP, 10/16/2016: https://youtu.be/DOqoe5f-GLY
    I've never seen them available for a CB. If they're not, I wonder if we could find someone to make them.
      You would need a front sway bar from a '92-'96 Prelude in order to get sway bar end links that are a combination of ball joint and traditional solid end links. Unless you went to a different lower control arm, or drilled a hole through your current one, you're restricted to using the method that the factory end link attaches to it.
        Is the 92-96 Prelude bar a direct bolt in?
        Stock F22A6
        H23A1 powered
