Hi everyone.
So i replaced my auto trans maybe a month ago, i did the 3x3 fluid swap and all was well,but the car always shifted a bit harshly. Today i adjusted my TPS and it has made a huge difference! the car is incredibly smooth now!
Here is my issue
the car would always shift at a maximum of 5.5, now it shifts at 6, after i did what i described below.
with my transmission cable connected, i could never get the TB to go to WOT.
i disconnected it and it works fine.
i tried to adjust it on the bracket but at max adjustment i could only get the TPS to read 4.3V.
what i did is take the cable out, and move both nuts below the bracket. this means nothing is holding it in, but it works properly now.
i think either the bracket is bent or the cable is too short. the motor is a prelude f22a1, maybe the transmission cables are slightly different lenghts? as i replaced it with a cb7 sedan transmission.
oh, and everyone ADJUST YOUR TPS! huge difference in power deleviry and gear selection.
also, drove up a hill the other day and the trans started to overheat, i believe this was due to the bad cable and bad tps adjustemnt causing the car to constantly change gears and get hot.
oh well, its sorted now.
So, any ideas about the cable?
thanks guys.
Here is my issue
thanks guys.
