Good Morning,
I think I'm getting the ECU code 90. It's kind of hard to tell when the blinks restart, so I thought about it and figured it could only be these 2 things 10 or 90. 1 or 9 long blinks and a slight delay at the end of 9 so like I said I'm not sure which but I think 9.
I used to have a problem with my ECT Sensor along with my IAT Sensor but both are replaced and it turned out to be a harness that was bad so I'm really leaning on it being code 90.
I've talked about my car having bog issues where I've fixed it, well it seems come and go, so I guess I never really fixed it but I'm really leaning on it being a vacuum leak and can't really pinpoint where it's coming from. When car is cold or on really cold days car runs great, when car warms up or on hot days car bogs between 1800-2300 rpms it seems like and will actually miss from time to time between that range.
Here's my question where or what is this: "Evaporative Emission Control System leak detected in the fuel tank area"
Note for question above, I've mentioned a "Groaning Noise" coming from my tank area before, and I was told from the forum it's "fuel pressure being released" I don't know if maybe this has anything to do with it?
One more note not sure if this helps as well. While using Cruise on the highway it will cut out when trying to pull up a hill or sometimes just when it feels like it. Never did this before started about 2 months ago. I'm really thinking a vacuum leak.
