Hey Guys, so I fixed my weird idling issue, it was a bad TPS.
When calibrating the new TPS, I could get it to exactly .5 Volts when the throttle was closed, but when I'd open the throttle all the way, it would only make it to like 4.35 Volts. I could bring the closed-throttle voltage up to get the right open throttle voltage (4.5 volts), but I wasn't sure what I should do?
Reason I'm asking is, I set it to be perfect .5 Volts at idle. Car idles pretty much normally, but when I WOT when driving it, it doesn't feel like I'm flooring it.
I drove the car with the bad TPS for about a week (before it started acting up), and It seemed to move a lot more when I floored it, then it does now.
It doesn't seem to be as loud or as growly as before I put in the new TPS.
I did research on it, and there was a lot of totally conflicting conclusions on forums.
