Hello Cb7 family!
I have been having a problem as of lately. So here is the run down so i was doing some keep up with my engine and had a problem with my vehicle speed sensor, and replaced the engine wiring harness from the fuse all the way to the fuel injectors. So after that change the car ran great then i took it out for a test run and went on the freeway the engine light went off and has been for almost two weeks. I already replaced the egr valves, replaced the intake , replaced the EGR valve sensor and as well as checked the hose line (16) and no dice. And I have searched around on the site and other places for an answer but I have tried but unfortunately have failed.
P.S
The car is running fine no change in idling or random lose of pressure so overall car running normal but just check engine light keeps coming on.
Thank you all for your time and hope to hear from you all soon!
P.S
