Well on my 5th gen i want to get better throttle response maybe.. i was wondering how to tighten the throttle cable a bit, i dont want to make it too tight that it will snap, and i want to make sure that doing this wont in any way cause damage to the car.. i know its not a 4th gen question but it seems like a basic same idea as the 4th gen.. i might be wrong.
Getting Better Throttle Response?
Throttle rotor, HUGE difference in throttle response from about 1/8 throttle to WOT!!!
Don't overtighten your throttle cable. Then the throttle will "stick."
Smaller crankshaft pulley, underdrive accessory pulleys, or both. I'm running without P/S or A/C, and this made a huge diff in throttle response... They're still on the car, just the belts aren't hooked up.1997 RHD AE111
JDM Blackface Project
Weapon R Throttle rotor, will get you to WOT 30-50% faster.
here the link http://www.weaponspeed.com/bithro.html
90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
< 317WHP/227WTQ@11psi> B/W S256 turbo, Daily Driving on 93 pump gas - since 2006. Driving Turbocharged CB7 Accord since 2002.
Yep, My self and many other have it, it great for WOT. Very easy to install, remove the nut holding the old rotor, slide the throttle cable off, and place the new rotor over the old one and put the throttle cable back on the new rotor. and tighten down the nut.
There is limited space to work, so be careful, and try not to drop the nut
Good luck,90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
i tried to adjust the two bolts before on the throttle cable and
it worked good but then my cars started ideling very wierd. it would pulisate up and down so i loosen it back up and it was all good. can someone tell me what i did wrong? it wasnt even that tight, it had like a 1/4 of a inch play!
JDMED
buy my jdm part
http://www.cb7tuner.com/vbb/showthread.php?p=544951#post544951
