Missing
    Missing
    I have a 1988 Honda Accord with 185,000 miles. I just put a new head gasket in, wires, plugs etc. Before I started it had just started missing, and after all the work it is still missing. Compression is pretty good, all around 130 psi. Where should I look next? Manual says "missing at idle" and "missing at all speeds" that the EGR might be at fault. What do you folks think?
    Thanks,
    Bill
    idk... but www.3geez.com might be a good site for you to check out.
      Yeah, head over to 3geez. I'm over there as well. We'll need more info like if it's carbed or fuel injected and whether or not you resurfaced the head and things like that when you put in the new headgasket.
