does anyone know if a oil sensor can leak oil??i have a 5 speed 91 sedan,wear is the oil sesor?and how hard is it to change,i think that is my oil leak because theres oil near/above the oil filter,but if the oil sensor was leaking would the oil light be on?i would rather have to replace the oil sensor and not the head gasket.
oil sensor
the oil sensor is a round thing directly above the oil filter. if it is indeed leaking from there try first to take it out and clean the thread..then put it back in and see if the leak comes back....What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
they should last, i say take it out and clean it....then put it back in...perhaps there is a o-ring on it that you can just replace...
iono how much they cost...not many people buy those partsWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
well if its around the oil filter, perhaps the oil filter isnt tight enough...usually a leak you can see a line if its from up top..like for example your oil pressure sensor..there would be a leak comming from that down...if not then thats not it.
if you see nothing comming from the top though then it may just be in that area...tighten the oil filter a little....clean around...drive and check again for leaks....
if u use teflon....be careful not to let it come off haha..there is something called umm...its for threadded fittings....usually for air or gas lines....its like plummers glue...its blue...makes a nice sealWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
