window comes off track enough to open door
    yeah it comes off track and makes a lound pop then the door open by its self so what do i have to replace?
    You hear a loud pop and the door opens by itself?
      yeah im guessing the window pushes on the door lock thing inside the door.. like how they break into your car or how you get in the car if you lock the keys in it
        Take off the door panel and check for loose/missing regulator mounting bolts. Also make sure the rollers that slide along the track (in the regulator) haven't popped out. Sounds like something is loose/popped out.
