as the title says i have a leak. I woke up this morining to go to work and noticed over night my car has leaked out most of the clutch fluid. i have checked everywhere i can think of, but still see no leaks any help is good help. it's not to big of a problem because i have like 6 bottles of brake fluid, but every time i add more the leak seems to stop. i have only had to fill the resevoir once since i bought the 6 months ago
where is it leaking from
Originally posted by xtremeskier97Yeah..you need to fill up the fluid, and then have someone press the clutch several times while you look under the hood for the leak.Quagmire: Hey there sweetie, how old are you?
Connie: 16.
Quagmire: 18? You're first.
Connie: Mom!
Quagmire: I like where this is goin'! Giggidy, giggidy, gig-gi-dy!
yeah i hate the distance too. but my neighbor is gonna help when he gets home in like an hour so it all works out. Thanks for the offer (if you were closer)Quagmire: Hey there sweetie, how old are you?
Connie: 16.
Connie: Mom!
check the floor inside the car right around the pedals, like where the floor and firewall meet. look there and im pretty sure you will find all that fluid you lost. if so, you need a new clutch master cylindar. if its leaking by the slave cylindar then you need to replace that.93 accord dx stock (mine)
91 accord lx stock (wife's) click here for the FS listing
86 crx HF (carb'd model) with B18B1 swap, custom OBD1 fuel injection conversion, custom mounts...... fun conversion, and more fun to drive
86 ford ranger with dual sparkplug 2.3 FI conversion
thanx for all of oyur help. i found that it is leaking from the slave cylinder and if any one has an extra for cheap i am interested. no BIG rush, cuz the leak isn't that bad yet. but i will need to replace in the next week or two, once again thanx cuz you all were a big helpQuagmire: Hey there sweetie, how old are you?
Connie: 16.
Connie: Mom!
