lightened pulley???
    lightened pulley???
    ok i know i read in one of the post that in order to run the lightened crank pulley you need different belts Gates K050410 and K040413. My question is what if your running without ac then what belt should you look for. Also between the two that are in this post which one is which p/s and a/c. Im only going to run the lightened crank and not the accesories.
    bump anyone??
      on my UR pulley, the belt part numbers were listed on the instruction sheet. Im sure if u call them up, they can tell u which u need to look for
      Formerly 91AccordExR33
      11.68 @ 127mph
      417whp/375wtq
      Sold: 8/2016
        well the ones that are on my sheet are for the p/s and the altenater & a/c. They dont have a number for a belt to go just from the altenater to the pulley?
          You are going to have to gauge it and buy a couple different sizes, and try a couple on. When I got my UR pulleys, the ones on the instruction sheet were wrong, I needed a smaller size. Pain in the ass, to be honest, but better be safe than sorry. If your belts aren't the right size=squeek city.
          My Member's Ride Thread, Comments Welcome!!!
