if i run a pt6-ex ecu with my lxf22a1 will that really kill that annoying 112mph speed killer, and will it boost my power any more even if i dont have the a6 manifold? also will a p14 ecu run my engine, and is my ecu code for an lx an pt3 ecu?
will a pt6 ecu boost my f221 anymore?
tofastfelonyTags: None
only part i can answer right now is the p14...im getting your other answers now.
NO h23 ECU is DOHC motor so youll have a DOHC ECU for your SOHC motor.
govoner i think is removable with chipping ECU..but im going to find you DEFINITE answers..
EDIT #1:http://www.cb7tuner.com/vbb/showthre...=speed+limiter
says that the PT6 removes the speed limiter/govenor
EDIT #2: yes the ECU is a PT3, non vtack sohc my dohc bull ish...Last edited by clarksterdotcom; 05-30-2005, 09:50 PM.
you wont see any noticable gains by just swapping out you ECU. you need to swap the IM over to see something at all. you might try searching instead of just posting and waiting around for an answer.
http://www.cb7tuner.com/vbb/showthre...ighlight=f22a6
need a answer on this plzzz
