Im getting my timing belt done tomorrow and they asked if it was one or two belts.....I didn't know what to say...can someone let me know how how many belts there are? thanks!!!
Timing belt 1 or 2 belts??
^^^and also what he said if your mechanic asked if you want both timing belts replaced you should be worried! when you took it to him for a timing belt he should have just suggested you to replace the balance shaft belt as well. if i were you i'd go back to the shop and question his knowledge.
CiRcuS kiNgZ
Better yet, don't go back.
The timing belt service is not hard, but like any car there is a way to do it right. Plus, while you're in there, not a bad idea to do the cam & balance shaft seals, balance shaft retainer clip, water pump, oil pump seal... blah, blah, blah...Bart: What's your name?
Jim: Well, my name is Jim, but most people call me... Jim.
YES, ^^^^what he said....Originally posted by GrayCarBetter yet, don't go back.
Definately do both belts, waterpump, cam seal, and balancer seal retainer at the very least. The balancer seal, crank seal, and gearset o-ring are up to you.00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
