I did a search and found some responses, but I would like to dedicate a thread to this specific question and hear from people that have used this product. I want to know if you have installed a Bosch O2 sensor and how long has it lasted you (please indicate if it went bad, etc).
The reason I ask is because on our 90 Accord EX I replaced the O2 sensor with Bosch OEM type (plug-in) like 3 weeks ago and reset the ECU (removed ECU back-up fuse & shorted ECU via touching battery cables to drain transistors in ECU for hard codes).
Anyhow, 3 weeks after this installation my dad encountered driveability problems and said the engine check light went off. I checked the codes to find code 43 and 1.
43 = fuel supply system
1 = oxygen content
So I didn't have time to diagnose it and my dad needed the car, so he took it to the Honda dealer. Anyways, they say the Bosch sensor is defective and will charge $250 installed for replacement with OEM part.
1 = oxygen content
