car dies when i come to a stop
    okay heres the situation my car after starting it up dies in the morning. It idles really low aswell and the next worst thing whenever i come to a stop it dies out aswell. Can anyone help me that has experienced this same stuff before?
    well mine did that but that was when the timing was way off (the cam gear slipped) and i was running it way to retarded in the first place so one day i was driving and when i came to a stop it died.. then i started it up and went then at the next stop light it did the same thing, after all day i found out it had to do with the cam timing... so just look into ur cam timing (cam gear), ignition timing, see if ur misfiring and such then get back to us...
    GET A TUNING QUOTE FROM ME AZ PEOPLE
    "TÜNE.FREE Engine Management!"
    ...::SHAWNEE::...
      Maybe a throttle position sensor?
        Do you have a manual tranny? Same thing happend to me back when I had my manual CRX. Turned out that a couple of vacuum hoses were unhooked.
          same...check vacuum line also to the brake booster as well.
            I found out what was wrong it was the sparkplug gromet seals on the valvecover. The sparkplugs got wet imma change em and see what happens
