So none of my interior lights are working. I checked the relay under the hood and that is fine, including all the exterior lights running through that relay. I checked all my fuses both under the hood and in the interior, and they are all good. Could the dimmer switch itself be faulty?
dimmer problems...
Yeah, none of the interior lights work. The dimmer relay under the hood controls the exterior lights (except for the headlights themselfs) and the interior lights. THe exterior lights work AOK, but none of the interiors do. But all my fuses are fine.Originally posted by evol90accordSo your saying the small light fuse *isn't* blown.... hmmmm. And none of the lights work? Not even like on the radio and a/c control? What the hell did you do?!
Its not that, because i tried another persons switch last night and still no interior lights. Any other ideas? I will try jumping some of the wires though and see what happens.Originally posted by accord91lxyes the dimmer switch itself could have gone bad and caused the problems you describe... you could take it out and jumper a couple wires and see if anything lights up...but look up the different wires first to see which ones to jumper.
