you guys migth know was causes over heat I try changing thermostat and I found that the previous fool took it out so it couln't be it.any ideas .radiator or maybe water pump. one guy said it could be worn head gasket any ideas
need help with overheating
Originally posted by 92CB7accordYou might need a new head gasket. How long do you have your car running until it starts to overheat?
Can you speak english? You have alot of typo errors.
more or less but that's not the point.you think that I need a head gasket. The car runs fine until I stop then it starts goin up then if I move again it starts to go down. but thanks man.
So.Cal outlaws
SOLD
are you sure you checked the right hose??? back behind the dist., down below it aways..the lower radiator hose- i think off hand.
theres a o ring seal that goes on the thermastat to seal it. with out the thermostat installed it would prob. leak, unless theres alot of silicone.
had a simular prob. with my therm. ... when it starts getting hot turn on the heater full blast and it should help drop the temp.
or poss. the fans
i assume that your not loosing coolant to cuase overheating......
91 ex 1badwag
91 lx wag (aka the beater)
92 ex 4-door
HONDA...its not just a way of life...its an ADDICTION!!!!!!!!!!!!
to che4ck if its your water pump wait until the car is cold then start it up with the cap off if you dont see any flowing water in the radiator then it may be the pump as for the thermostat make sure it out before you start the car to check for the pump but leave the seal im there like there was a thermostat in there first. If you dont see any fluid moving around in there its your pump. If you noticed its not stayin at normal temp its your thermo if both of these dont help its your headgasket be sure to do a cr test on it to confirm it
Radiator Cap....could be leaking pressure which will cause your car to warm up after sitting.....1991 Honda Accord Ex
Pics of the beast!
::::198.4 WHP and 146.6 WTQ Currently weighing in at 2700lbs...best time: 14.8@92mph::::
2003 BMW 330I Sport.....Daily Hustler....
Road Race #1
Totoro Squad #2
