strange warning light problems
    Check your connections back there.
    Tail lights and brake light connections.
    Heat makes it expand, therefore not making contact.
      Brake fluid level may just be low, this will cause the light to come on. Either that or the master cylinder cap float is sunk in which case you have to replace the cap.
      00 Jeep Grand Cherokee 4.7 V8 4X4
      92 Honda Accord LX
      95 Honda Civic CX
        had the same problem, check ur brake sensor and connection in the right tail light
          mine was like that, the bulb wwas just going bad. i changed the bulb and it never gave me an on/off thing anymore..
          but that's just me.
          the door ajar, im not too sure though.
          hahahahah
