Your heard it. About a year ago I got a Shift Knob, Pedals, and Valve stem caps from in this pack from Autozone for 5 bux. I install everything (The shift knob is retarded and never fit). So this morning I went to go check my tire pressure becuase it looked low in the front and I couldn't get the caps off. So for the last hour I have been using the blade of a metal saw to cut through the stupid little things. GAH! Everytime I do a project it seems like I get it shoved in my ke-ster. So anyways after I got the caps off I checked the pressure and they were all 30. Well the fronts look WAY lower than the backs. I have 4 Kumho's all the way around and they are about a year old. The max PSI on the Kumho's is 44. Should I be filling to this or what is on the door jamb?
1 hour Tire Inflation Job! QUESTION! WTF!
yay for cheap autozone parts
Originally posted by AccordAnimal...I have 4 Kumho's all the way around and they are about a year old. The max PSI on the Kumho's is 44. Should I be filling to this or what is on the door jamb?
never checked what it says on the door jamb, but i believe 32-34 psi is just about right.5.6L V8 32V DOHC
JDM HERITAGE - US BUILT
do not fill it up to the max on the tire.. this is the max it will hold with the added weight of the car, drivers and whatever else.. if you say, fill it to the 44psi, then decide to pack your car full of people, that puts a lot of added pressure on the tires and they will easily blow.. when at jiffy lube, we looked in the door jamb if they had stock wheels/tires and read the tire and put 10 less if they were aftermarket.. i got to the point of just simply checking the tire because of all the different types of tires out there..
as far as the valve caps.. you get what you pay for..
i was always afraid to fill my 17s to the max because the sidewalls got rock hard and the ride was absolute shit.. i always filled them around 10 or so psi less..
