is my idle right
    is my idle right
    my 91 ex 5 speed idels at 800rpms when its warmed up,is that right?it seems ti idle fine but can i turn it up a little,what are the pros and cons of turning up the idle,will it make taking off in first gear less shaky?is it even supposed to idle at 800rpms,it idles 2 lines before the 1.thanks
    800-900 is perfectly fine for the warm idle. depending if u have ac and ur amp going it might jump a lil higher but its perfectly normal /
