My battery gets messed when im using my car the RPM go under ones at sometime and my volts go to 10. I was wondering if i need a new battery? What's the best one to buy? Let me know thanks
12 Volt Charge
Re: 12 Volt Charge
Your voltage should never drop to 10, I would check your altenator. The problem is probably there.Originally posted by Maple50175
your battery should show 12.3+ with the ignition off and nothing on
with tthe car running and the normal accesories running your battery should read 14.4+ and nothing less then 13 if it does then you have a bad alt
if you voltage readings are fine while the motor is running but bad when off then you have a bad battery
if you need to replace your battery and your car is stock then go for a OEM battery (more expensive but the best) if you have a modded car and alot of electronics or car audio equipment then go for a Optima or larger battery that can handle the added run down time
my .02
hope that helps
well what did it do????
u can also take it to a auto store, most of the time they do free checks.
mine runs at 12.3 when nothing is on...when its on it raises to like 13.4...around there and just sits there but never drops below..What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
