dizzy compatability
    dizzy compatability
    sup guys
    im runnin a F20A DOHC and i believe my cap/rotor is off of a 2000 civic SI.
    I was wondering if a OBD1 SOHC distibutor cap will work on my motor since I want to convert to external coil. Anyone know for sure that it will work?
    thanks, Lee
    Formerly 91AccordExR33
    11.68 @ 127mph
    417whp/375wtq
    Sold: 8/2016
    ok, so you are currently using the F20 internal coil distributor with a '99 Si cap and rotor, right?
    since the F20 dizzy is comparable to all other DOHC dizzies, then you should be able to use either a H23A1 or a USDM H22 cap with respective rotor buttons
    someone else verify this, although i am fairly confident
      right, but are all honda dizzies different>? I found an MSD cap from a SOHC OBD1 that i want.
      11.68 @ 127mph
      417whp/375wtq
      Sold: 8/2016
        From what i know, There are only two style dizzy caps within the 4 cylinder engines. I dont know all the applications to each but i can tell you that the f22b1 dizzy is different from the f22a dizzy. Thus, the two styles of caps. After that each style cap should fit most of the other 4 cyl hondas. The cap we use are commonly referred to the civic 1.6 obd1 caps.
