Yep, Engine bay rear cross beam, I bent it. I've got it ALMOST out, but I can't figure out what's still retaining it. I spent until 2am last night trying to figure out what the hell was still bolted up to it... but so far we've had no luck.
The mounting bolts, rear engine mount, power steering rack, steering column shields, etc. are all out, but for some reason the beam is still in there quite solidly.
Does anybody have any ideas as to what could be the culprit? If anyone has a HELM I would be your friend for life if you'd post the removal procedure as my Chilton's doesn't cover it.
Thanks
*EDIT* the LCA's are unbolted, too
Thanks
, and a steering column yoke bolt later it dropped right out. Unfortunately I had previously pulled the steering rack resistance bolt, which may not be so fun to put back in and adjust properly, thinking that it was the yoke bolt.
